Re: Minarelli v1 piston issues
P D /
> >>>taykoff [s2m] Wrote:
> I really can't tell how bad the head is here or if all of the damage was
> done to and caused by the head gasket. I would advise against running a
> stock v1 head gasket on a kit, or you run the risk of that gasket
> expanding into the bore area and getting torn up by the piston...which
> is what I think has happened here.
Looks like pieces of ring stuck in the head , to me .
Agreed , I'd smooth things and remove anything not suppose to be there and run it ,provided what we see is the only damage .
Sure there might be a bit of carbon build up in the crevices , but so what ?
