Re: Need a repair man
Pops Peds /
One thing to check also is the vacuum line going to the petcock..they will sometimes go bad and pull fuel into the vacuum line..you can pull the line off at the petcock when it stalls to see if it has any gas in it..good idea to change your gas lines also..they come apart on the inside and clog the carb
