Re: Need a repair man
Moped Lar /
If the idle jet is clogged, sea foam isn’t gonna help much. The holes in the idle jet are so tiny, the only way to properly clean one is with very thin gauge wire.
Another thing to check in the carb is the vacuum diaphragm. If the diaphragm is in any way damaged or distorted, you’ll get similar symptoms.
