Re: Motobecane D55 Motor Teardown
Dirty30 Dillon /
So I finally took the time yesterday to sit down and address the grooved clutch basket.
I was trying to figure out a way to utilize a grinder, or Dremel to work most effectively, but in the end there is no replacement for the flatness and accuracy of a handtool.
Bench Setup, was able to keep the angle on the fingers by using the table as a parallel guide. worked really well.
End product. I only removed about 1.5 mm of material, and then cleaned up the shoulder. Can't speak highly enough for having good quality files (Nicholson Single Bastard and Swiss) double bastard for fast removal of the material, than single/finish to lean a clean surface, with the half-round Swiss 00 for chamfering and edge-breaking.
I guess the next steps are to button up the trans side. The PO used red RTV as a gasket, but despite the size I think I am going to try and cut a fiber one. Barring success with that, I will use ThreeBond.
  Motobecane D55 Motor TeardownTopic by: Dirty30 Dillon Dirty30 Dillon 04/15/20 09:50AM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 04/15/20 10:05AM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 04/15/20 10:36AM
  Re: Motobecane D55 Motor TeardownRe: P D P D 04/15/20 11:35AM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 04/15/20 12:33PM
  Re: Motobecane D55 Motor TeardownRe: P D P D 04/15/20 12:48PM
  Re: Motobecane D55 Motor TeardownRe: Rebel Moby Rebel Moby 04/19/20 12:19PM
  Re: Motobecane D55 Motor TeardownRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 04/20/20 09:36AM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 04/20/20 10:11AM
  Re: Motobecane D55 Motor TeardownRe: Ian T Ian T 04/30/20 02:07PM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 04/30/20 02:12PM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 05/19/20 09:46AM
  Re: Motobecane D55 Motor TeardownRe: P D P D 05/19/20 10:45AM
  Re: Motobecane D55 Motor TeardownRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/20/20 01:26PM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 05/21/20 10:47AM
  Re: Motobecane D55 Motor TeardownRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/21/20 12:23PM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 06/15/20 10:09AM
  Re: Motobecane D55 Motor TeardownRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 06/15/20 12:12PM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 06/15/20 12:22PM
  Re: Motobecane D55 Motor TeardownRe: Rebel Moby Rebel Moby 06/15/20 10:20PM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 06/15/20 11:22PM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 06/18/20 01:01PM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 10/11/20 11:53PM
  Re: Motobecane D55 Motor TeardownRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/12/20 07:02AM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 10/12/20 09:45AM
  Re: Motobecane D55 Motor TeardownRe: Rebel Moby Rebel Moby 10/12/20 01:16PM
  Re: Motobecane D55 Motor TeardownRe: Satan 666 Satan 666 10/12/20 06:20AM
