Re: Motobecane D55 Motor Teardown
Dirty30 Dillon /
> Brandon Weiss (Detective brandon to you) Wrote:
> This is so cool, looking forward to seeing more of this. Transfers are
> yuge
> As far as the tooth wear, it's possible that it was run with low or no
> oil? Not sure of there are other signs that would support it or not.
There is a V good chance that it was run dry, at least a little bit before I got it. But I really can't say for sure. I filled with clean oil before I started, and it was noisy on first start up. But telling by the odd plate wear on the hub, that sounds pretty fair to say.
For now I will sharpie mesh the gears and clean up the hub fingers.
  Motobecane D55 Motor TeardownTopic by: Dirty30 Dillon Dirty30 Dillon 04/15/20 09:50AM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 04/15/20 10:05AM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 04/15/20 10:36AM
  Re: Motobecane D55 Motor TeardownRe: P D P D 04/15/20 11:35AM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 04/15/20 12:33PM
  Re: Motobecane D55 Motor TeardownRe: P D P D 04/15/20 12:48PM
  Re: Motobecane D55 Motor TeardownRe: Rebel Moby Rebel Moby 04/19/20 12:19PM
  Re: Motobecane D55 Motor TeardownRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 04/20/20 09:36AM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 04/20/20 10:11AM
  Re: Motobecane D55 Motor TeardownRe: Ian T Ian T 04/30/20 02:07PM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 04/30/20 02:12PM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 05/19/20 09:46AM
  Re: Motobecane D55 Motor TeardownRe: P D P D 05/19/20 10:45AM
  Re: Motobecane D55 Motor TeardownRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/20/20 01:26PM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 05/21/20 10:47AM
  Re: Motobecane D55 Motor TeardownRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/21/20 12:23PM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 06/15/20 10:09AM
  Re: Motobecane D55 Motor TeardownRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 06/15/20 12:12PM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 06/15/20 12:22PM
  Re: Motobecane D55 Motor TeardownRe: Rebel Moby Rebel Moby 06/15/20 10:20PM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 06/15/20 11:22PM
  Re: Motobecane D55 Motor TeardownRe: Dirty30 Dillon Dirty30 Dillon 06/18/20 01:01PM
