E50 Puch compression
I have a 1978 Maxi, Tccd 70cc kit. Running 2 base gaskets, stock 50cc head, and 2 thin head gaskets (I was concerned about clearance). Compression reads 110 pounds. Should I get another head, that is for the 45mm piston? Remove 1 head gasket? Thoughts?
Re: E50 Puch compression
I'd only use a single head gasket .
Hand turn the crank to test clearance , but , it should be fine .
