Re: Carb jet needle question
Tim Doll /
I have another problem with the carb today after cleaning it again. It’s leaking non-stop from the bottom overflow tube I spent hours trying to fix it . My first and obvious thought was the float sticking, but that’s not the problem I took it down the basement and rigged up a fuel system using water.Im using the same parts as before and had no problem with leaks .i placed around with the peacock unit thinking maybe screwed it up . Nothing worked Do you have any idea what would cause this other than the float? Thanks
