Re: Carb jet needle question
Tim Doll /
Thanks for the tips. Will the bike basically idleing for a long period of time carbon /soot up even if set up right? Compression is 85 on my Harbor Freight tester . The manual says 90-95 is spec . The main jet that came with the kit is #80, the original on it is #88 ,the air /fuel jet is 38 with the kit and original is #35, should I use the original idle screw also . Where can I get an o ring for the base of carb.ill piddle around wit it today. The cub came out beautiful and everything seems to function well,just the nagging idle problem. Thanks again
