Re: Carb jet needle question
Tim Doll /
I’ve been trying to get the original carb to run but haven’t quite got it yet; I’ve cleaned it several times , installed a rebuild kit .cleaned the fuel tank and replaced the fuel lines. The problem is all low speed , idling speed is erratic and sometimes stalls like it’s not getting fuel I’ve cleaned the float.replaced the valve and jet . No vacuum leaks.
I’m working on the peacock assembly now .I just can’t seem to get any consistency.
It’s also running rich , however it’s running almost always on idle
