My engine on Honda Cub 50cc runs too rich , lots of soot on the spark plug .In the manual it says to lower the E clip one notch . My question is do I move it toward the blunt end of the jet needle or the pointed end ? Thanks
You need the needle to.go lower in the jet...move the clip.toward the top or blunt end of the needle
Thanks for the information, that’s the way I moved it but wasn’t sure, it’s still burning rich but I have one notch left maybe I’ll move it . Would a different air/fuel low speed adjustment screw valve make a difference also? It’s a Chinese clone carb but runs good , I was thinking about taking the air /fuel valve from the original carb and swapping it with the Chinese carb. Thanks again
Carb is too big for it.
Do you mean the carb is too big for the needle ?
No he's saying the carb itself is too big.
Best to fix and use the original.
I’ve been trying to get the original carb to run but haven’t quite got it yet; I’ve cleaned it several times , installed a rebuild kit .cleaned the fuel tank and replaced the fuel lines. The problem is all low speed , idling speed is erratic and sometimes stalls like it’s not getting fuel I’ve cleaned the float.replaced the valve and jet . No vacuum leaks.
I’m working on the peacock assembly now .I just can’t seem to get any consistency.
It’s also running rich , however it’s running almost always on idle
There are some real small passages in those carbs but once clean and sealed, they run real well. If you have access to an ultrasonic cleaner, or buy a jewelry ultrasonic cleaner maybe on amazon, or buy the one gallon Gunk carb soak and soak for a week. Follow up with chasing passages with speaker wire strands, carb spray and compressed air. Mounting flange- check flatness, use small thick flatwashers not lockwashers. Use original jets and not ones that come with carb kits.
Also make sure the mounting spacer is flat, new o-ring, base gasket, Hondabonded.
Any little airleak in the setup makes them sputter and not return to idle fast enough for a smooth shift. I have gone through every leakpoint by replacing the little o-rings in the carb.
Thanks for the tips. Will the bike basically idleing for a long period of time carbon /soot up even if set up right? Compression is 85 on my Harbor Freight tester . The manual says 90-95 is spec . The main jet that came with the kit is #80, the original on it is #88 ,the air /fuel jet is 38 with the kit and original is #35, should I use the original idle screw also . Where can I get an o ring for the base of carb.ill piddle around wit it today. The cub came out beautiful and everything seems to function well,just the nagging idle problem. Thanks again
Its s non-standard o-ring size. If you get one from Honda, try ebay ir dratv.com. Making 2 gaskets for each side is the other option.
I have another problem with the carb today after cleaning it again. It’s leaking non-stop from the bottom overflow tube I spent hours trying to fix it . My first and obvious thought was the float sticking, but that’s not the problem I took it down the basement and rigged up a fuel system using water.Im using the same parts as before and had no problem with leaks .i placed around with the peacock unit thinking maybe screwed it up . Nothing worked Do you have any idea what would cause this other than the float? Thanks
Water is thicker than gasoline .
Pull the carb and polish the float seat bright shiny . Inspect the needle tip for any deformities . Check float level .
I lapped my needle to the needle seat with fine Clover compound, never leaked since.
I might have found the problem after hours and hours of piddling around . When I went through training for running machines at Timken Bearing our instructor told us the most beneficial tip . He said if your machines are running along fine and all of a sudden things go South, ask yourself the question What did I just do ? In this case I new it was something I did but couldn’t think what it was . The filter cup was rusty so I soaked it overnight in evaporators. I just happened to pick it up for the umteeth time
,looked at it under a magnified light and it had around a dozen small holes ,the evaporust ate the rust off that was covering the holes, that’s what hopefully is causing the problem. I coated the holes with J-B Weld and will give it a go tomorrow. In the meantime I ordered a used carb that came off a 65 Cub , same as mine . Thanks for all the feedback.
Doubtful that JB will hold for very long .
The carb from EBay should get here soon ,maybe that part will be good. I just tested it for leaks and it works so those pin holes were the problem. Thanks
Good find!
The carb looks to be in good shape I’ll have $50 worth of fun just tinkering around with it , add it to the pile of fishing reels and other stuff laying around collecting dust. It’s amazing how much you can learn about problem solving just tinkering around . One question on this carb . There’s a piece on the Petcock assembly called the cock packing , does this have to be in a certain place ? Mine has 7 holes and a solid area in which a hole is skipped . I don’t want to screw this up too. Thanks again
