1980 Motobecane/Motomarini Sebring NO Spark
kelly kissman /
I'm about to purchase a 1980 Sebring. It turns over and has compression, but has no spark. Before I purchase I want to make sure I can either repair the potential problem or be able to find the potential part (pretty much hoping I can find that part on treatland. Anyone have any information to share? Also, I'm expecting to rebuild or replace the carb. I've seen videos that had Sebrings with SHA carbs. Does the 1980 use the SHA too? (edited)
Re: 1980 Motobecane/Motomarini Sebring NO Spark
I don't want to be negative, but I will say GOOD LUCK, and that mopeds are more than just one problem. They require an extreme amount of time, sacfirice and commitment to get them to move. That's my experience with french mopeds.
I just have to have to say that. Be ready.
Second, in terms of parts, go to treatland.tv
Best moped parts store. Up in Norcal, see if they have the parts you want.
^ Sebring's are not as obnoxious as say a 50v, I would grab it, they are nice bikes.
You'll figure it out. Clean the points, check the kill switch, possibly replace the condenser.
Don't buy a rust bucket. Your already gonna need new tires, engine seals, possibly brake pads even on a good looking bike
kelly kissman /
https://mopedarmy.com/forums/read.php?2,4339362
This is the one... doesn't appear to be a rust bucket.
GET IT - no spark is often a easy solve because it has the blue wire scheme for the US market. The exciter coil for the ignition also powers the tail light, ground that wire and hardwire the tail light and the headlight for all the time lights. Also a tuneup and you are on the road...
Well - what are you waiting for...
kelly kissman /
Deal's done. Just waiting to drive there this weekend... 600 miles round trip.
Wow! 600 miles for a Sebring! YOU are my kind of person! You will love the big strong Sebring, as compared to a lot of wimpy step-thrus.
Easy to work on the Morini or Minarelli engines. Yours should be a Morini.
kelly kissman /
From what I can tell it's a Morini M1.
kelly kissman /
So the intake is mounted to the case and not the cylinder? Does the starter clutch lever operate a lever on top of the right side engine cover?
> trip.
60 miles is my limit!
> nice bikes.
haha my Peugeot 102 and Motobecane 50V have scarred me for life!
Glad you got it OP.
kelly kissman /
yes, it's a case reed valve engine. And the clutch lever thing, I don't know.
kelly kissman /
what does the Sebring use as a CDI?
That's the single speed, M1 ………..great engine! Kit it with 60 cc and put a pipe on it.
