Re: PHGB 19.5 starting/idling issues on a sachs 505
Mason Campbell /
> pat splat Wrote:
> theres an idle jet and and idle enrichment screw, your going the wrong
> way. Little idle screw out to enrichen, in to lean.
> The idle speed screw lifts n lowers your throttle slide. in your slide
> is your needle height, up to enrichen earlier. Lastly the choke makes
> life easier for cold starts and if buggered would mess up everything.
> don't run that 72, too small.
Is the idle enrichment screw the little golden one next to the idle screw? And I just ordered some new idle jets today as well. I bumped the main jet back to 82. Once started it seems to run well. But it still won't idle. I will take a look at the needle as well and see if maybe I need to back it out some. I'll start with the enrichment screw. And I went lower because on the last two bikes I've done I've had to go lower than expected. I'll keep tinkering. Thank you very much for your input.
