Re: electric problems
Rebel Moby /
Not the correct switch for the wire diagram you have shown.
56 should be headlight, 54 should be tail light, B(30 or 51) should be battery
Missing terminal on the switch so pressing a button will make a connection to the frame to sound the horn
Missing a terminal on the switch so pressing a button will make a connection to the frame to kill the engine ignition
Get the correct switch and connect at the DIN coded terminals
Gelb - yellow should be connected to B (or30 or 51)
Braun - brown should go to headlight 56, (taillight is branched off the terminal for headlight or can be 54 on the switch)
Blau - blue should be for ground to sound horn 71
Schwarz - black should be ground to kill engine 1
