Re: A35 case open and clutch inspect help?
Hills are not the reason for your problems..unless you weigh 300lbs.
I see nothing wrong with your crank, the splines and threads and bearing surface looks fine. If you were indeed missing the thick shim behind the clutch bell, that would certainly cause metal flakes in your oil because it would allow the bell to rub on the gears to the right of it.
  A35 case open and clutch inspect help?Topic by: Marc Alan Marc Alan 04/05/20 11:17AM
  Re: A35 case open and clutch inspect help?Re: pat splat pat splat 04/05/20 05:27PM
  Re: A35 case open and clutch inspect help?Re: Marc Alan Marc Alan 04/05/20 06:05PM
  Re: A35 case open and clutch inspect help?Re: Marc Alan Marc Alan 04/05/20 06:07PM
  Re: A35 case open and clutch inspect help?Re: Marc Alan Marc Alan 04/05/20 06:11PM
  Re: A35 case open and clutch inspect help?Re: Marc Alan Marc Alan 04/05/20 06:12PM
  Re: A35 case open and clutch inspect help?Re: Marc Alan Marc Alan 04/05/20 06:52PM
  Re: A35 case open and clutch inspect help?Re: Marc Alan Marc Alan 04/05/20 06:42PM
  Re: A35 case open and clutch inspect help?Re: ♣Slew Foot♣ ♣Slew Foot♣ 04/05/20 08:21PM
  Re: A35 case open and clutch inspect help?Re: pat splat pat splat 04/05/20 08:26PM
  Re: A35 case open and clutch inspect help?Re: Marc Alan Marc Alan 04/05/20 08:32PM
  Re: A35 case open and clutch inspect help?Re: Marc Alan Marc Alan 04/05/20 08:38PM
  Re: A35 case open and clutch inspect help?Re: Marc Alan Marc Alan 04/05/20 08:39PM
  Re: A35 case open and clutch inspect help?Re: Marc Alan Marc Alan 04/05/20 08:43PM
  Re: A35 case open and clutch inspect help?Re: Marc Alan Marc Alan 04/06/20 02:25AM
  Re: A35 case open and clutch inspect help?Re: P D P D 04/06/20 08:38AM
  Re: A35 case open and clutch inspect help?Re: Marc Alan Marc Alan 04/06/20 10:28AM
  Re: A35 case open and clutch inspect help?Re: Marc Alan Marc Alan 04/06/20 10:34AM
  Re: A35 case open and clutch inspect help?Re: Dirty30 Dillon Dirty30 Dillon 04/06/20 11:35AM
  Re: A35 case open and clutch inspect help?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 04/06/20 10:51AM
  Re: A35 case open and clutch inspect help?Re: Richard Eberline Richard Eberline 04/06/20 11:57AM
  Re: A35 case open and clutch inspect help?Re: P D P D 04/06/20 12:07PM
  Re: A35 case open and clutch inspect help?Re: Marc Alan Marc Alan 04/06/20 02:15PM
