> pat splat Wrote:
> its rich then, take a look at your plug, oily n black? fouled? u can
> test by taking off the filter all together, and run with just the black
> cap, or no cap. that'll lean everything up and confirm your running
> rich, or experiment with the number of screens, more screens equals
> richer, im guessing 3 screen black cap and a 64. of course get a couple
> new plugs as well, maybe a higher temp ones too.
So there isn't a very noticeable difference with no mesh or no cap. I may be just running that rich. I mean it bogs out in the low range at full throttle. Once she revs up a bit you can tell it's running better. I have a new plug ready to go. Just waiting to use it with the new jets so I can get more accurate readings. Once I get it dialed in with the carb stock air filter I'll either upgrade carbs at a later date or experiment with thinner mesh filters for the SHA. I just wasn't sure if my main jet in this carb would effect my idling.
