Hey guys I bought the 70cc Athena kit from treats. They sent 2 base gaskets. Any reason to this? Is it for spacing? Do I just pick one and go with it?
When you install the cylinder , you should check the port timing .
The piston top edge should be level with the bottom of the exhaust port when at bottom dead center .
Adjust via base gaskets .
Ahhhh got it! Thank you!
