Re: Stud removal
Jack Nielsen /
Loctite and CRC both make freeze sprays that come out at -20 degree F and will make the stud contract and allow the liquid to seep in between the stud and the exhaust header. Alternate between a torch on the exhaust header (expansion) and freeze spray on the broken stud (contraction) along with a few gentle taps with a hammer several times and then let it sit overnight and it should come out with a needle nose pliers. All of the above ideas will work just be careful
Jack
