1983 Yamaha RX50
Got this thing pre pandemic just ordered some crap for it hopefully treats is still able to ship stuff .... does anyone know where I can get the wrench to take off this exhaust nut? I’ve been really patient and haven’t even looked for the chisel yet
Re: 1983 Yamaha RX50
I use channel locks.
Rich Condor /
Yea I could do that but I plan on taking this on an off a few times so I can build a custom pipe and don’t want to crush it or mess it up...they must sell a tool but I googled it and haven’t found it (edited)
> must sell I tool but I googled and everything and haven’t found it
I have a rd60 and if you use the right you won't. I put th top jaw in one groove and let the bottom jaw rest about half way down the side and turn.
Rich Condor /
Man I was really hoping I would get to buy some fancy castle wrench for this thing
Chris Molden /
Shock preload spanner, or strap type oil filter wrench?
Rich Condor /
Ha not sure I was hoping someone with a YSR or RD would know which one to get I had an old Ducati once that used a special exhaust nut wrench I figured Yamaha would offer one for this maybe they do I just haven’t found one
Rich Condor /
^^^ one of these might work are they universal?
That's what I posted a link of.
Make one. Should be pretty easy.
They used to include these in the tool kits that came with the motorcycle since at least the 60's. I've 5 or 6 in my toolbox.
That's a fact . (edited)
Pushrod Fifty /
I use an aluminum rod and ball lien hammer to get mine off and then channel locks to tighten, not too much because my cylinder is cast iron.
I have a ysr50 and Suzuki A100
Channel locks work just fine for me .
But I’ll order that set of wrenches to try out
Rich Condor /
Any idea where I can find the bolt for this luggage box? I think the original was like a big wide Phillips head
I'm sure you could find something that'll work at your local hardware store .
Rich Condor /
Ya a bolt off the side of the case will work with a washer but I’m in no rush just looking for what would have been there originally it is a Yamaha the bolt/part is probably used on other bikes
Beach Club Nick /
Look at the YSR50 rear tail box bolt
Rich Condor /
Any pictures of one ? It’s really weird how you can find anything on google until it’s the thing you need and are ready to buy it. I really want to grab the spanner wrench assortment posted above but I also want to find an OG tool kit so I can keep it on the bike
PS.... got it running today it still leaks everything gas from the carb and tank petcock and brake fluid from the diaphragm not exactly sure which carb rebuild kit to get for this Mikuni the needles look worn one is squared off at end... idk this seems like fun once it’s dialed in tho it started first kick (edited)
There's likely a model identification on the lower side of the carb body , just above the bowl .
