Dies with throttle.
Melker Stalnacke /
Hallaow!
I have somewhat a weird issue with my TMS Motard 5 which uses a Minarelli AM6 engine. I cannot make it idle without using the choke, and even then it will only run for like 5 seconds before it dies. If I were to use the thottle it would die immedietly. My problem does get a little weirder though, I can start it and have it idle if I tilt it to the right. And then I can start it back up again if it is already warm.
I have been told to clean my carb which I did today, but without success. I am not very experienced in this field and I hope some of you have the knowledge needed!
