M48
Having issues with my bat-
It won’t run under load-
Idles fine, Revs fine, but as soon I get on it I go about 90’ feet or less and it dies-
Help!
I don’t wanna go another season with this bike not operable-
Re: M48
Justin Tolentino /
As it sits.
Re: M48
♣Slew Foot♣ /
Condenser. Clogged screen cup in banjo.
Re: M48
Justin Tolentino /
I just cleaned the banjo- I guess I try the condenser- but it’s pretty new I thought it would last longer-
Re: M48
Electronics can be bad right out of the box .
If you can , buy a Bosch condenser . The best available .
Re: M48
Justin Tolentino /
Ima dig the the hand full I have here but I’ll order a new one too- (edited)
Re: M48
is there a choke? use it.
Re: M48
♣Slew Foot♣ /
It might be a lose ground. The points insulator sleeve cracked. The blue wire under the pointset is bared.. Does it start right after?
Re: M48
Justin Tolentino /
Starts right up every time, just won’t pull any load... on the stand it will rev forever- think it maybe seals?
Re: M48
♣Slew Foot♣ /
Good guess...
Re: M48
♣Slew Foot♣ /
Maybe No friction disk left
Re: M48
Pushrod Fifty /
Could use an exhaust cleaning.
Re: M48
crank seals
engine is easy to work on
straightforward repair
