Malossi race gears (vespa bravo)
Robert Emery /
The problem I'm having is my rear pulley is not engaging when pedaling the motor with decomp engaged. I installed malossi race gears via the wordpress toot. Every combination of shims. If you run malossi gears what are the perfect shims to make it work? Or what can be an issue. Front variator is shimmed as well.
