Re: Need help to remove torrot turismo victoria variator
Rebel Moby /
If the variator is staying engaged then you need to get the front cover off and free up the little starter arms so they do not stay engaged. Open the front cover you will see them and just use some WD40 or penetrating oil to get them to move freely, then chase away all of the penetrating oil with brake cleaner. The arms should be able to rotate on the pivot without any oil because the oil will just chase out with the centrifugal force and contaminate the clutch friction surfaces.
  Need help to remove torrot turismo victoria variatorTopic by: kim koo kim koo 03/25/20 08:45PM
  Re: Need help to remove torrot turismo victoria variatorRe: Nick MBC Nick MBC 03/26/20 01:51AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 08:38AM
  Re: Need help to remove torrot turismo victoria variatorRe: Stephen Keller Stephen Keller 03/26/20 03:46AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 08:42AM
  Re: Need help to remove torrot turismo victoria variatorRe: Nick MBC Nick MBC 03/26/20 03:24PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 03:26PM
  Re: Need help to remove torrot turismo victoria variatorRe: pat splat pat splat 03/26/20 12:41PM
  Re: Need help to remove torrot turismo victoria variatorRe: Dr No Fun Dr No Fun 03/26/20 02:58PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 03:23PM
  Re: Need help to remove torrot turismo victoria variatorRe: Rebel Moby Rebel Moby 03/26/20 03:27PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 03:48PM
  Re: Need help to remove torrot turismo victoria variatorRe: Rebel Moby Rebel Moby 03/26/20 03:59PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 04:05PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 05:19PM
  Re: Need help to remove torrot turismo victoria variatorRe: P D P D 03/26/20 05:38PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 10:53PM
  Re: Need help to remove torrot turismo victoria variatorRe: pat splat pat splat 03/26/20 11:38PM
  Re: Need help to remove torrot turismo victoria variatorRe: Nick MBC Nick MBC 03/27/20 01:40AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/27/20 07:26AM
  Re: Need help to remove torrot turismo victoria variatorRe: Stephen Simmons Stephen Simmons 03/27/20 07:44AM
  Re: Need help to remove torrot turismo victoria variatorRe: Rebel Moby Rebel Moby 03/27/20 09:12AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/27/20 09:43AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/27/20 09:50AM
  Re: Need help to remove torrot turismo victoria variatorRe: Rebel Moby Rebel Moby 03/27/20 09:51AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/27/20 10:21AM
  Re: Need help to remove torrot turismo victoria variatorRe: Stephen Simmons Stephen Simmons 03/27/20 09:37PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/28/20 08:32AM
  Re: Need help to remove torrot turismo victoria variatorRe: Daniel '' Daniel '' 03/28/20 01:19PM
  Re: Need help to remove torrot turismo victoria variatorRe: Rebel Moby Rebel Moby 03/28/20 03:39PM
