Re: Need help to remove torrot turismo victoria variator
Rebel Moby /
I have never seen a US version of the Torrot bikes, so no 'blue wire' to worry about grounding out to allow the coil to spark. Two condensers on these bikes, one in the points the other on the ignition coil. The one on the coil is supposed to be for RF noise suppression not spark quality. I would suggest to worry about the ignition first before the variator if you need/want the bike to be running.
Clean the ignition points with small file and chase off any guck with brake cleaner (NOT abrasive paper and carb cleaner as either will leave shyte behind that will mess with the contact) set the gap at 0,4mm at index and set timing to 1,5-2,0mm BTDC. If no joy then disconnect the points and make sure of continuity when closed and open circuit when open. Check the condenser that is loads and unloads. Check the internal ignition coil, should be 1-2ohm. If still no joy after all of that is correct then check the external coil which is all the heck the way up above the seat post tool box. 2000-4500ohm for secondary to primary depends on which coil they have up there, 1-2ohm for the primary to primary. Make sure you dont have a resistor plug and resistor cap, you need either or none but not both.
Posts above have the opening of the clutch pretty well covered...
  Need help to remove torrot turismo victoria variatorTopic by: kim koo kim koo 03/25/20 08:45PM
  Re: Need help to remove torrot turismo victoria variatorRe: Nick MBC Nick MBC 03/26/20 01:51AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 08:38AM
  Re: Need help to remove torrot turismo victoria variatorRe: Stephen Keller Stephen Keller 03/26/20 03:46AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 08:42AM
  Re: Need help to remove torrot turismo victoria variatorRe: Nick MBC Nick MBC 03/26/20 03:24PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 03:26PM
  Re: Need help to remove torrot turismo victoria variatorRe: pat splat pat splat 03/26/20 12:41PM
  Re: Need help to remove torrot turismo victoria variatorRe: Dr No Fun Dr No Fun 03/26/20 02:58PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 03:23PM
  Re: Need help to remove torrot turismo victoria variatorRe: Rebel Moby Rebel Moby 03/26/20 03:27PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 03:48PM
  Re: Need help to remove torrot turismo victoria variatorRe: Rebel Moby Rebel Moby 03/26/20 03:59PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 04:05PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 05:19PM
  Re: Need help to remove torrot turismo victoria variatorRe: P D P D 03/26/20 05:38PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 10:53PM
  Re: Need help to remove torrot turismo victoria variatorRe: pat splat pat splat 03/26/20 11:38PM
  Re: Need help to remove torrot turismo victoria variatorRe: Nick MBC Nick MBC 03/27/20 01:40AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/27/20 07:26AM
  Re: Need help to remove torrot turismo victoria variatorRe: Stephen Simmons Stephen Simmons 03/27/20 07:44AM
  Re: Need help to remove torrot turismo victoria variatorRe: Rebel Moby Rebel Moby 03/27/20 09:12AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/27/20 09:43AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/27/20 09:50AM
  Re: Need help to remove torrot turismo victoria variatorRe: Rebel Moby Rebel Moby 03/27/20 09:51AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/27/20 10:21AM
  Re: Need help to remove torrot turismo victoria variatorRe: Stephen Simmons Stephen Simmons 03/27/20 09:37PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/28/20 08:32AM
  Re: Need help to remove torrot turismo victoria variatorRe: Daniel '' Daniel '' 03/28/20 01:19PM
  Re: Need help to remove torrot turismo victoria variatorRe: Rebel Moby Rebel Moby 03/28/20 03:39PM
