Re: Need help to remove torrot turismo victoria variator
pat splat /
interesting, never seen this one but before u try get everything ready, grease puller threads, grease up a small washer to fit on that point and distribute the twist, test fit puller all the way in then back of a bit, center bolt in all the way in and then back off a bit. Now take the puller off put the crank nut back on loose.
Blast the area with a torch, nut on (30 sec.) back out the nut, prepped puller on and pop that baby off. Once its all snugged up it should pop in a 1/8 to 1/4 of a turn or so. Whatever u do, dont mash your crank threads, its easy to do.
  Need help to remove torrot turismo victoria variatorTopic by: kim koo kim koo 03/25/20 08:45PM
  Re: Need help to remove torrot turismo victoria variatorRe: Nick MBC Nick MBC 03/26/20 01:51AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 08:38AM
  Re: Need help to remove torrot turismo victoria variatorRe: Stephen Keller Stephen Keller 03/26/20 03:46AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 08:42AM
  Re: Need help to remove torrot turismo victoria variatorRe: Nick MBC Nick MBC 03/26/20 03:24PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 03:26PM
  Re: Need help to remove torrot turismo victoria variatorRe: pat splat pat splat 03/26/20 12:41PM
  Re: Need help to remove torrot turismo victoria variatorRe: Dr No Fun Dr No Fun 03/26/20 02:58PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 03:23PM
  Re: Need help to remove torrot turismo victoria variatorRe: Rebel Moby Rebel Moby 03/26/20 03:27PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 03:48PM
  Re: Need help to remove torrot turismo victoria variatorRe: Rebel Moby Rebel Moby 03/26/20 03:59PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 04:05PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 05:19PM
  Re: Need help to remove torrot turismo victoria variatorRe: P D P D 03/26/20 05:38PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/26/20 10:53PM
  Re: Need help to remove torrot turismo victoria variatorRe: pat splat pat splat 03/26/20 11:38PM
  Re: Need help to remove torrot turismo victoria variatorRe: Nick MBC Nick MBC 03/27/20 01:40AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/27/20 07:26AM
  Re: Need help to remove torrot turismo victoria variatorRe: Stephen Simmons Stephen Simmons 03/27/20 07:44AM
  Re: Need help to remove torrot turismo victoria variatorRe: Rebel Moby Rebel Moby 03/27/20 09:12AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/27/20 09:43AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/27/20 09:50AM
  Re: Need help to remove torrot turismo victoria variatorRe: Rebel Moby Rebel Moby 03/27/20 09:51AM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/27/20 10:21AM
  Re: Need help to remove torrot turismo victoria variatorRe: Stephen Simmons Stephen Simmons 03/27/20 09:37PM
  Re: Need help to remove torrot turismo victoria variatorRe: kim koo kim koo 03/28/20 08:32AM
  Re: Need help to remove torrot turismo victoria variatorRe: Daniel '' Daniel '' 03/28/20 01:19PM
  Re: Need help to remove torrot turismo victoria variatorRe: Rebel Moby Rebel Moby 03/28/20 03:39PM
