Re: NU50 high RPM to start spin wheel
Jack Rutherford /
That belt is so long that you can here it hitting the inside of the case at idle. It’s going to require more throttle than usual to take out the slack. It’s width is also a problem as it forces you to start out in higher gear than stock belt thus requiring more throttle.
