triple check your timing, points. i dont think moby ignition goes thru brakelight but is somehow attached to that horn button/ kill switch/on off. your clutches should definitely catch at that speed. once timmed, spray some premix directly into carb to find out if its lean. the exhaust nut is loose but check if the muffler clogged?
