1982 Honda Urban Express electrical issue
I just bought this moped and none of the lights work and I can kick start it and it runs well. Looks like it has been re wired with a new battery. Does anyone have any way to diagnose?
Re: 1982 Honda Urban Express electrical issue
Diagnosing electrical is almost a hands on job ...i think there is a wiring diagram in the wiki..have you checked the bulbs to make sure they are good
I have a wiring diagram but I have no experience with them, have not checked the bulbs however I used a power meter and measured nothing
You can use a couple of pieces of wire to check your bulbs on the battery headlight
..one wire for plus and second to ground ..the tail light bulbs touch the center then to positive ...touch second wire from neg to base of the bulb
If it was run without a battery the bulbs could well all be blown, if it was all rewired check for a hidden switch? Maybe contact po and see if they have any insights?
Pierce Holcomb /
I was given an 82 honda urban express, 632 miles on it, saving it from being scrapped..it looks to be complete but has 2 issues..no spark and no lighting except for the license plate and brake (?) Lens..I did connect a battery to it, it does turn over,and the light on the cdi unit flashes while the starter is cranking..any ideas what to look for?
