Benelli G2
What exactly is the air vent valve that is located under the seat on the frame?
Is there a passage from that to the gas tank?
Put some cleaner in the gas tank to clean it and started to swish it around and fluid came out that vent? Hmmm?
Re: Benelli G2
Jeremy Homser /
Its an air bleed valve so you can fill the tank with fuel completely and not have trapped air in the tank
Re: Benelli G2
Robert Parr /
Thank you!
