Re: Fuel lines
Born to be WillD /
one is the reserve and one is regular. the normal operation one draws from a few inches off the bottom of the tank, the reserve draws from the bottom, so if you run out at the normal one you've got still a few miles reserve to get to a station. the reserve needs a filter for sure. you select on/off or reserve with the little selector on top of the float bowl where the lines both go the top/side of the carb
