> Jack Nielsen Wrote:
> Everyone: Thank you all for the suggestions. I took the carb off,
> removed the bowl and inspected the needle valve seat. It was clogged.
> Tried to clean it with carb cleaner to no avail. Hooked up the air
> compressor and pumped 50 pounds of air through the gas inlet and
> discharged a bunch of crap in the seat area. Put the carb back and now
> it runs. Still runs crappy but it runs. Thanks everyone. Jack
That clog should prompt you to insure that every passage , jets and air passages are clear .
