Re: Hobbit - no fuel in carb bowl.
taylor Vogel /
If it’s the stock carb, the bowl will screw on 2 ways, but only one is right. You want to put the bowl back on with the drain tube at the bottom facing the choke side... this could be your issue. Good luck
