been a while since I've asked for help here but I have 3 bikes, pug, puch, moby.
They all run great but the moby 50V takes far more effort than the other 2 (especially if it's sat for a while).
Anyway, runs fine once started and it starts right up after it's been warmed up and running but to get it started initially it takes a good bit of peddling to fire. btw, with the decomp on and the choke pulled in it definitely has a fair amount of resistance on the pedal stroke then the other bikes...almost feels like a heavy handed clutch holding it back at start up but once running it runs just dandy...
timed at 1.3 btdc, good healthy spark, stock vario and starter clutch etc, stock points ignition, good gas flow
what would you think is the most likely reason?
thx!
