The on/off dial on the switch seems to be stripped out, the brown wire and violet wire which is cut at the switch, are the same colored wires going into the horn. Should i clip those wires at the horn, or leave them alone, reconnect the 2 at the switch and get a new switch? Going through Wiki and wiring diagrams, doesnt really show what the end result would be if i clipped the same color wires at the horn and switch. Its a clean Type A (30 mph) 50V totally complete with the original spark plug and I just want to take this out for a ride so bad! This horn is so annoying! Thanks
