Re: Forgot to lube crank bearings-duh
Rob Abbott /
Yes, new bearings are in. I dremeled the ports to case match before I reassembled the case, but failed to: a) lube my new bearings; and b) grind down the infamous za50 tab before putting the case together. Dumb. There is a reason I'm not designing rockets. I will likely use the play-dough trick to grind the tab.
