My targas LX has no brakes lights, like no tail light and no brake light, I cant get the head light to work either, I dont know what it is, can someone help me with installing the brake light and troubleshooting the headlight? thank you
Yeah google has photos of your electrical wiring for your bike. Just ask google for light wiring diagram for your exact year make n model.
Idk how to wire anything to save my life bro
Try to learn. That's what its about.
Have you replaced bulbs? Checked for voltage with a dmm?
theres only so many connections, wiggle each one so the contacts r freshen up, same with the switches.
if u dont have a tester, hold the bulb up to light and see if the filament is busted.
forgot to add, tomos rear wheel tends to rub the wireing harness under rear fender, take a peek as well.
Start with the yellows out of motor use a bulb to chech for power. Brown are ground except off regulator reg should be mounted mid bike to discharge without back surging up the ground to blow bulbs. The pos. Can all be run together. Then your brakelights on use hand signals.
Theres this box of connections on the left side of the bike, theres so much grime and dirt on it I cant really tell what it is, but theres a fat wire that runs to the box and splits into a bunch of connections and those connections run to the rear and front headlight can anyone tell me what that is?
Voltage regulator two yellows and a brown discharge to ground. Yellows are next to each other the brown on the next side.
One is power in from mag other regulated voltage to the electrical system.
Moped mentalism is tough pics?
your looking for a whats called a wiring diagram and a rag and some awesome.
If all you want is to be spoon fed "to-do's" , you've chosen the wrong hobby.
