Re: Grande rear hub oil question
Eric C /
> Dirty30 Dillon Wrote:
> So a little bit basic knowledge, but that's a dry clutch. You can
> probably tell that there's no way that an assembly with two open holes
> on the exterior could possibly hold oil.
> The oil you have is for use in the transmission, and I have highlighted
> the fill bolt for the trans.
> The broken spring is a starter clutch spring, and probably resulted in
> making the bike not idle off the stand, if at all. That whole clutch
> assy needs to be cleaned and serviced.
What are my objectives when I disassemble the clutch to freshen up? I understand the basic centrifugal function (I think) but other than that I feel like I'd be going in blind. I'm having no problems, very easy starts and idles fine, so I'm tempted to just replace the springs, check out the shoe surfaces and where they are grabbing and then hands off, but figured I might as well ask and learn.
