Re: shortening puch throttle cable
Nate K /
> baird co Wrote:
> Treats has mini knarps, but are you saying you need a ball end for the
> lever?
> If so, You can modify your lever by carefully drilling the round ball
> end hole bigger (if there's enough metal around it) to fit a mini knarp.
> Did that to a vintage throttle and it worked fine.
> If you have a mig welder, you can shorten the carb end. Just cut the
> cable, clean it real good, and zap it right on the tip of the cable.
> Makes a perfect ball.
prefer the lever/throttle end as getting the ball thru the tube on the top of the carb can be a little tricky
