Re: shortening puch throttle cable
baird co /
Treats has mini knarps, but are you saying you need a ball end for the lever?
If so, You can modify your lever by carefully drilling the round ball end hole bigger (if there's enough metal around it) to fit a mini knarp. Did that to a vintage throttle and it worked fine.
If you have a mig welder, you can shorten the carb end. Just cut the cable, clean it real good, and zap it right on the tip of the cable. Makes a perfect ball.
