Re: 1980 Honda express NC50
Mark Kieper /
I ended up finding a tank that didn’t leak between the oil and gas. Did the same thing with RedKote just to help protect it and make it last.
All is good with this classic however if I ride it full throttle for about 10 minutes it will die. It normally will start right back up however thinking it must be a gas issue. Wonder if the peacock is clogged with a little rust from the old tank. Might try to clean that up or just replace it
