Re: 1980 Honda express NC50
Don Ohio /
If yer using brick cleaners' acid(usually Hydrochloric,Muriatic), cut it at LEAST 3 water to one acid. It will still do the job. Let it sit for a few hours.
Neutralize the tank with baking soda and then final flush with water, dry it out and spray WD40 in there to coat it.
But first add gas to see if it's leaking thru to oil tank.
Keep pure water or a hose around for your eye protection.
