Re: 1980 Suzuki FA50 Stock Speed Issues
Aaron Reaves /
update:
pulled off the filter outer cover, ran it, gained 2 mph, then pulled over removed the plastic insert that sits on top of the filter material, and got it up to 25-26 MPH ish which is almost close to what it was doing before carb cleaning.. thoughts?
It will not run at all without the air filter, will idle but throttle will bog it down killing it. However filter cover off, and plastic insert that sits on top of "foam or cottonish" material it almost gets back to where it was.
Also choking at startup works as should. however trying to throttle or run it with choke on results in bogging it down to where it will die. (edited)
