kill switch hookup
im hooking up my kill switch and i bought a three prong toggle switch. i know on goes to power but what does off and the ground on the switch go to? can i ground the ground on the switch and send the off to ground? is that how it works?
Re: kill switch hookup
Not very water resistant type switch. Just get a push button starter switch. When you push it,the bike engine dies if the other side is grounded..
> grounded..
have one, i dont plan on riding in wet conditions tho
im trying to do this setup
i should have mentioned im installing a second one somewhere on my bike as a anti theft deterrent too
Run the spark to the switch, then ground the other side
Flip the switch, ground the spark
Badabing badaboom
You have that mounted in a bad place. Your leg will be rubbing on that cover constantly,looks like to me.
thats not my bike, it was an example of where abouts i was going to mount it
> Badabing badaboom
on----off----- ground
[ignition] [ground] [ground]
do i have that correctly?
> > Badabing badaboom
Is it on-on or on-off-on?
What you want is the ground and spark to be connected when the switch is thrown
A multimeter on continuity setting would tell you what you need to do
Oh shit it's probably a on off with a ground. Just connect the on-spark and the off-ground leave the ground tab on the switch alone
this makes the most sense but i needed confirmation other than myself. thank you so much
i was overthinking this a lot, im glad its solved now i can put a hidden kill switch on my bike
Good you have the simple grounding switch figured out .
Think about using a simple magnetic switch for your anti theft switch .
You could mount it anywhere that's convenient , in plain sight or hidden .
Maybe a flush mount type and simple plate magnet .
As long as the magnet is in place , the bike runs .
Remove the magnet and the bike is dead .
And , there's no obvious switch .
