Re: Batavus m56 clutch starter not engaging
spencerrrrr r /
Ya it was just pressed on, when I tired to grind down that nub in the inside it popped off pretty quickly. The plate wasn’t deformed, I think the repaired nub was just a bit long.
Ended up using an m5x10 bolt and an acorn nut to make a new contact point. The bolt head had to be ground down a bit but it works now.
