Re: Motobecane av7 crankcase gasket issues
John Ebert /
I had the same issue with a carb kit I got for the Gurtner on my 63 AV88. Nothing worked quite right, while it looked right in the picture in application it wasn't.
If you have to make a gasket put oil on the surface of the crankcase to mark the gasket paper and make a pattern. You can pick up gasket punches from HF at a minimal cost. I would use Yamabond or 3Bond which is the same stuff. Some of the liquid gasket material you can get from your local parts store doesn't play well with gas, read the label before you buy.
