Re: 77 Newport Kickstand Pedal Clearance Issue
Mike Boyd /
> pat splat Wrote:
> i think your making this too complicated. Theres no grease nipple on the
> end of the pedal shaft where it connects to pedal arm.
Some Puch pedal shafts do have a grease nipple zerker fitting. And yes, those are one piece meaning the pedal can't be removed separately from that side. Hard to get accurate info on this forum sometimes...
I would either weld the tab on the kickstand back up or get another OEM used Maxi-length kickstand that is complete and see if that fixes your problem first. Also if you can post pics of the contact point that would be helpful too!
