Re: 77 Newport Kickstand Pedal Clearance Issue
Ty Griswold /
I should have mentioned that, I did unbolt it, and other than the cracked stop on one side, the stand itself appeared to be symmetrical and not noticably bent. It was really filthy, so cleaned it up and freshened the grease and put it back together. I had been hoping there was some slight adjustment in the cap/?clampy? (not sure the correct term) that hold the stand pivot section in place. But not luck there.
The broken corner I spoke of doesn't appear to adversly effect the "clampy" alignment. I do need to reweld that other stop at some point anyways, so I suppose just cutting the other one off and reattaching it wouldn't be much more effort...
I was just hoping there was some kind of adjustment I was overlooking.
