02 Honda Met 50 loses power instantly when key is tuned
Christian Curby /
Hello I am brand new to this forum and this is my first post. I recently found two scooters that were in like new physical condition but didn’t run for a couple hundred dollars. One just needed a battery and carb clean and it is going but the second one needed a bit more.
So I have replaced the fuel pump, fuel lines and filter, cleaned the carb and replaced the battery. When I turn the key the scooter lights up for about a second and then there is an audible click and then the scoot loses power.
My buddy said it sounds like a bad solenoid but my local parts dealer had to order one so I thought I would post to see if anyone else recognizes the issue.
Thanks so much!
