Re: Resistance is Futile
Trent Anderson /
> Tri-ped Dave Wrote:
> I have literally 50 resistors NOS if you want some
I might want a handful in the near future.
If I ever get to my trike build, I will most likely use my multi-colored primer red and black Motron. So when I get to adding tail lights to the Pryer rear end, would I put a resistor in each tail light or just the first one and then run the second in parallel?
