Help with Peugeot regulator
I keep blowing headlight and running/brake lights aren’t working properly so got a new regulator but the color designations on the regulator don’t match wires on bike so not sure what wire goes to which prong. I know bottom right says headlight so I got that one. (edited)
Re: Help with Peugeot regulator
Bump
it works as an air coil transformer - The two yellows are either side of a coil - the terminals marked "Volantmag" and "Phare." these run from a lighting coils to the headlight. when the headlight is turned on, it induces a current through the other coil - "blanche" and "feurouge" (ground and taillight/speedo bulb).
https://www.mopedarmy.com/wiki/Peugeot_wiring_diagrams
here is another thread that may help
https://www.mopedarmy.com/forums/read.php?6,4291015,4291441,flat=1#msg-4291441
this should be all you need to figure it out!
