new kit new problems e50
I switched over to a kstar 70cc kit and once i put the head on and bolt it on, when i go to pull the clutch and pedal its super tough almost like its seized but if i take the head off and do it its fine. the cylinders not marred up or anything and the piston moves back and forth fine so i now its not seized. Im stuck on this problem. any advice is appreciated
Re: new kit new problems e50
How much compression does the motor have ?
i dont have a tester but it blows my finger away if i crank it
Dirty30 Dillon /
Are you using a stock head, or cut head for the increased displacement
Did you space the squish properly? Piston prolly hitting the head.
cut head 70cc hi comp
have a 70cc head gasket in, also sanded the head too
Dirty30 Dillon /
My guess is that your piston is impacting the head.
Any sign of contact between piston and head ?
Get or borrow a compression tester .
You can blow a finger off a hole with what you have in your lungs . Doesn't tell much .
> Doesn't tell much .
not that i can tell, im about to order another head gasket and see if thats the problem
does anyone know the specs to the 70cc head, measurements of the squish? i have it 40mm and want o double check im not using the wrong head
Solved: i had 2 50cc heads, one i thought was 70cc and a 70cc head that i thought was 50cc. took some measurements and 2 were the same, the last was much much different.
Thanks everyone
> Thanks everyone
You're welcome , but , that^ doesn't solve anything except your confusion . LOL
What did it take to make your motor easier to start ?
And , how can heads be the same , but much much different ?
> P D Wrote:
> that
> last
> > Thanks everyone
> confusion . LOL
2 measured out to be 38-40mm last one was way bigger like it fits a 70cc piston in the squish band, all 3 of them are dirty so they looked the same. Try cranking a 70cc piston with a 50cc head on and it wont go
edit:i have 3 heads, 2 50cc, 1 70cc (edited)
Ahh . You should have said that first . We're not there , looking over your should , to see that . ;)
The devil is in the details , minor as they might be .
Sorry i thought i typed it out in second to last response, guess i wasnt clear enough
> clear enough
No worries . I've been less than clear more than once .
Painting a picture that others see as we do , sometimes take a bit of doing . :)
I have a 50cc head on a 70 kit. I was going 41MPH, 2 nights ago. Pulled clutch to see why it grabbed so EARLY, screws were all the way out. My compression is 110. Guess I need another head? Couldn't test tonight (float stuck).
